XRC 10 winch not working
Old Nov 26, 2009 | 04:50 PM
jeepmedic's Avatar
Default XRC 10 winch not working
Help !!!
I attempted to install my brand new Smittybilt XRC10 winch tonight....
I have no power to it. The manual lever does not work. When the remote is plugged in, nothing works and the in/out lights do not even light up. I am able to free spool the line out.
The install instructions I thought were pretty hard to mess up...and I have done the following things..
1. Rechecked all wiring to make sure it is in the proper place (it is all color coded and labled)
2. Rechecked battery terminals for tightness and making sure + to + and so on.
3. All other accessories mounted to the battery are working fine.
4. The main ground is direct to the battery.
Below are pics of the instructions and the wiring on the back of the winch all hooked up.
HELP
Old Nov 26, 2009 | 04:55 PM
Sethc84's Avatar
Not that its your responsibility but i would check the connections inside the solenoid (control box). I just finished wiring my xrc8 earlier today, same schematic and works fine.
Old Nov 26, 2009 | 05:01 PM
jeepmedic's Avatar
checked those too, they are tight....
Old Nov 26, 2009 | 05:05 PM
wal0vitch's Avatar
it could be a ground........ If i where you I would put my ground on the Neg terminal on the battery. Just for grins and see if it works...
Old Nov 26, 2009 | 05:10 PM
jeepmedic's Avatar
I have grounded it to the A terminal as shown and the main Ground to the battery.
Forgot to list that
RevyJKU08's Avatar
Should have got a WARN....
Just tease in you! I was looking at this winch as well...but shipping to Canada was a killer...reaching the price of some Warn winches. Hope you get it figured out and once you get it working...have a
Old Nov 26, 2009 | 05:11 PM
jeepmedic's Avatar
Does your remote "snap in" or just kinda "sit" in the control box. Mine just sits in there, No "click in."
Old Nov 26, 2009 | 05:27 PM
hammerhead's Avatar
You push in and twist to install the remote. Mine is tight going in and locks after twisted.
Old Nov 26, 2009 | 05:56 PM
Sethc84's Avatar
yes you push in and make a slight turn clockwise. you then need to hit the little metal button to remove. if you can pull the remote plug out without pressing that button then it is not in correctly. Hope that helps
Old Nov 26, 2009 | 06:09 PM
captjay's Avatar
you can try tapping on the solenoid, sometimes they just stick. also, are u hearing any clicks, noises of any kind when u try to run it
