XRC bumper problem
hello
I am a fairly new Jk owner and I wonder if any one has had a problem with rear XRC bumper with the tire carrier hiting the body of jeep . it only happens when going through deep pot holes . If any one has any ideas why this happening and a fix I would really appreciate it
Thanks
Thanks
It's happened before. I think it's somewhere in this thread. Give it a look, I'm too lazy to search through it all.
https://www.jk-forum.com/forums/show...XRC-Arrrggghhh
Here is a copy from a similar thread...if you can do a search for XRC HELP you'll find a thread on the exact topic.
Victim of the bumper hitting the passenger side body. After the first install of the XRC - driver side had a 1/4" gap, but the passenger side only had about 1/16". Well I opted to not do the washer body lift, guess I just like the pain of removing the bumper. Today I took the XRC back off the jeep and opened up the 4 holes in the frame crossmember. After reinstalling I now have a 1/4" gap between the body and the bumper on both the driver and passenger side. Took it for a test drive and no more bump, thump, knock....wow what a difference....
Originally Posted by nukeman
The rattle with the XRC is usually caused by the bumper hitting the rear corners of your tub/body when you travel over bumps. Install some washers in your body mounts and it will go away. Basically do a 1/8" or 1/4" body lift using washers.
