XRC Rear Bumper...3rd Brake Light?
Old Mar 16, 2010 | 08:52 PM
Randy Watson's Avatar
Default XRC Rear Bumper...3rd Brake Light?
I got my XRC rear bumper today and we looked at the instructions. What concerns me is that there aren't any directions addressing the 3rd brake light. For those of you who installed one with the tire carrier what are we supposed to do with the third brake light? Yes, I can call the tech support hotline when we're ready to install the bumper, but just thought I'd get some input here first.
Old Mar 17, 2010 | 05:30 AM
jvalason's Avatar
Mine came with a 3rd brake light bracket...Mine is over a year old though so maybe they come without now?
Old Mar 17, 2010 | 05:32 AM
tslewisz's Avatar
Have you checked your state regs to see if it's even needed? Here in Illinois they aren't. The Fed law says that vehicles have to be equipped with them to be sold, but that's it. I think they're ugly so I cut mine off.
Old Mar 17, 2010 | 09:40 AM
nukeman's Avatar
Yeah, they really don't address in the instructions how to assemble/install the 3rd BL.
Disassemble your old one by removing the torx screws that secure the lens to the OEM spare tire bracket. Install it in the bracket Smittybilt gave you, then install that into the other bracket they gave you. Mount the whole assembly to the tire carrier. It mounts between the spare tire bracket (one with the wheel studs) and the carrier itself using the supplied wheel stud bolts. You will probably understand it better once you put the pieces together. It's flimsy as hell when mounted. I installed two screws in mine through the brake light bracket and into the carrier to stiffen it up.
Old Mar 17, 2010 | 11:22 PM
Thanks!!!!
Old Mar 17, 2010 | 11:42 PM
johnboy194's Avatar
Smile
I had the same problem when I installed mine. I got a warning from a cop at the auto craft center about not having a 3rd brake light on my jeep. Its like a $75 fine so I broke down and got this relocation bracket.
http://www.4wd.com/productdetails.aspx?partID=54519
Old Apr 2, 2010 | 01:13 PM
Originally Posted by ffjc813
The 3rd brake light bracket from Smitty is awful...flaps in the wind with my top off and I don't know about these lug nut lights. Something about them rubs me the wrong way. I need to do something since I just have a wire tucked under my tailgate.
Any other suggestions?
Old Apr 2, 2010 | 01:45 PM
jvalason's Avatar
Yeah mine flops and bangs around also...lol. I'm going to work with what they made and make it stronger. Its something to start with thats not that bad anyway
Old Apr 2, 2010 | 02:28 PM
Dex1's Avatar
I did'nt use mine.... I don't need no stinking 3rd break light!!!
Old Apr 2, 2010 | 03:37 PM
Bosox5's Avatar
Veteran: Coast Guard
Ditch the light!!
