YILES! First death wobble.
Been driving the same highway with same bumps for almost a year. Hit a small bump where highway meets overpass pavement and BANG! DEATH WOBBLE. had to pull over to shoulder and come top stop to end it.
What changed? Last night I removed a 3/4 inch Daystar spacer and factory swaybar links from front and replaced with Spacers and longer links from TF leveling kit. Must be issue with longer links. If it happens again the factory links are going back on!
Think I found my issue ...
When I did the TF kit I also swapped my KM's to SRA's at the same time. I found that I had never torqued down the lug nuts on front driver side after I dropped it off the jack ....
Lug nuts were all pretty loose ....
