You have 12 hours to talk me out of this
#21
When choosing between 17's and 15's money shouldn't really be a factor. It is a couple hundred bucks and you are committing to five or six years of tire at least. I'm more concerned about performance. The extra 10 lbs per tire is a huge factor for me. I'm not building a rock crawler, yet, but I do put more miles on the trail then on pavement and plan to keep it that way.
From everything I've read on the Wild Peak it is a great performer on everything but mud. It also wears well, a lot of guys say they look new at 30k. I will be talking to DTD about fit but they have already confirmed the 15 x 8 will fit the JK. The caliper issue seems to be a steel wheel problem.
I've got gussets on my list, possibly sleeves too. As far as the lift, I've had people I trust swear by the dualsport and I don't want to go higher. I would rather start trimming than raising COG more than I have to. This lift is specifically designed to fit 35's though so I should be okay.
#22
I'm not sure you'll be able to tell much difference in COG for a 1/2 inch in lift. The Rancho kit comes with adjustable upper control arms front and rear, front links, front brake lines, front adjustable trackbar and with the adjustable RS9000 shocks would cost you less than the AEV kit after the rebate. It just seems like more bang for the money.
Gary
#23
I research things to death. I'd like to call it a hobby but it really becomes obsessive. I have the money but I was waiting for backup money. Then I saw DTD has a deal going down where I get a $100 visa card for both tire and wheel purchase that ends tomorrow so an extra $200 sweetened the pot.
I want the Falkens cause I run desert with pointy rocks and freeway. In my research they are tough in rocks, amazing traction and quiet on the road. Heavy but I'll sacrifice weight for durability and traction. I've read they aren't great in heavy mud but that just doesn't happen much in the desert.
I want the Black Rock d-windows cause I am looking for a wheel that doesn't look like it belongs on a street car. I also like the contrast between the tungsten ring and the black hub. I'm thinking I want a 15" because it's a ten lbs difference between a 35x15 and a 34.5x17.
The AEV 2.5 DualSport XT is a bit of a wild card but I really want to stay low COG and prime DD with a solid trail crawler. I've heard this is the package. I was tempted to save cash and go TF but I think the upgrade in ride will be worth the extra cash.
Where I'm a bit lost is rim width. They offer an 8" and 10". The tire suggests an 8.5 to 11. I know the 8" fits the JK without mod, the 10" is the same BS so I assume it would fit too. I have know idea other than speculation that the 8" is supposedly better at low pressure holding a bead.
#24
I would go with the 17's if you plan on hitting the rocks. The 15 has a wider sidewall which translates to better chance of puncturing it, and a better chance of bead off when aired down. I have the black rocks with the round windows in a 17x9 which has performed great. I chose the Toyo Open Country M/Ts for the durability factor. The side wall is almost as thick as the foot(but they weigh in pretty heavy). In the end it's what you want.
#25
Originally Posted by ASSFROW
Sounds like you have a plan and it's not changing, but weight of 15 inch wheels and 35's 91 lbs. 17 inch wheels and 35's 97lbs.
Gary
#26
Wheels from Black Rock webite 15 inch 19lbs 17 inch 23lbs
Wild Peaks from Falken website 35x12.50x15 72lbs 35x12.50x17 74lbs.
15 inch tire and wheel 91lbs.
17 inch tire and wheel 97lbs.
Only 6lbs difference per wheel.
#27
Wild Peaks from the Falken website, but the weight I listed includes the wheels.
#28
#29
I think I was reading a thread a little bit ago but it all went south into a childish Internet battle and I gave up on it. Is it the Rancho Trail 3" you are talking about? On Quadratec's site only half of the 4" lifts are part of the "Shock and Awe" promo, none of the 3".
Have you run a Rancho or have friends with them specifically this lift? I wish I could drive them both to compare. My other concern is I've read 3" lifts are the start of drive shaft length issues tearing boots and replacing or extending brake lines.
#30
Here are a couple of links to some Rancho threads I found helpful.
https://www.jk-forum.com/forums/modi...130258/page45/
https://www.jk-forum.com/forums/spon...-227066/page6/
Here are the links to the new Rancho kits and rebate form.
KITS Rancho Suspension: Suspension » 2012 Jeep JK Wrangler - 2 & 4 Door 4WD Suspension Systems, Lift Kits, Leveling Systems & Shocks
REBATE http://www.gorancho.com/promotions/S..._RebatePad.pdf
Hope this helps,
Gary
