Zone 3" lift
Old Oct 23, 2008 | 09:42 AM
  #41
lv jk's Avatar
***erator
I would get a kit that you cane upgrade arms and track bars at a later date as you get the cash. I just added the front top and bottom arms and track bar to my 3" lift and the jeep rides much better. In many cases if you mix different manufactures parts they will not honor warranty.
Old Oct 23, 2008 | 10:24 AM
  #42
TeraFlex's Avatar
Sponsoring Manufacturer
TeraFlex is all for customers buying our products to make another brands kit more complete.
Old Oct 23, 2008 | 11:57 AM
  #43
officer_vince's Avatar
I'm going to upgrade to control arms over winter.
Also going to "upgrade" to a teraflex CB antenna mount ahha...figured I'd throw that out there since teraflex posted on here
But I am very positive of the Zone 3" kit....I can't see putting another company's control arms on the kit voiding the spring warantee...my local 4x4 shop has spoken personally with Zone and said they are top-notch with regards to warantee.
Old Oct 24, 2008 | 06:00 AM
  #44
Sethco's Avatar
I think any kit can be considerd incomplete to someone. You show me any kit and I can show you something I needs to make it more complete or better. There is no such thing as a complete kit for everbody. But for the one that wants to start moding and is on a budget this is a great kit, you can always add components as you go.
Old Oct 24, 2008 | 07:46 AM
  #45
wayoflife's Avatar
JK-Forum Founder
really? then by all means, please tell me what more needs to be added to something like a currie rock jock suspension system to make it more complete? how about a full traction long arm kit? in spite of what you'd like to believe, we are talking about suspension here and there is a science to it. while you may be able to get away with less or tollerate substandard handling or ride quality, that does not mean you can't get a kit that IS complete and will allow you to dial in your ride - for EVERYBODY.
at 3" of lift (most likely a bit more as most 3" coils are) and with the few componets that are included with this kit, i personally would disagree and i think many others on this forum would as well. at least, i can't count how many times i've heard people complain about "flighty" steering or wandering issues after installing a cheap 3" lift that had no means to address caster or provides a solution that most of the people i know eventually regret using. likewise, i can't count how many times i've heard people looking for a way to recenter their axles. sure this kit comes with a rear drop bracket but nothing is included to address the front end. if you or anyone else is really determined to get this kit, i would strongly recommend that you pick up at the very least, a set of adjustable lower front control arm. these will set you back about $250. an adjustable front track bar would be great to have too and that will cost you about the same as well.
IMHO, if budget is critical and you're looking for a setup that'll clear something like 35's, i would recommend something like a teraflex 2.5" budget boost and a PA 1" body lift to go with it. together, you will have everything you need to run 35's and without any problems. also, at this height, you won't need new drive shafts front or rear regardless if you have an auto or not. as far as track bars go, a drop bracket is included for the rear and while an adjustable unit up front would be nice, the axle shift you'll see won't be enough to require one. while some people have expressed issues with "flighty" steering after installing this lift, most have not. of course, the higher you go the more this becomes a problem - at least, unless you address your caster with adjustable control arms. kidjeep has this setup now and can follow me just about anywhere including the rubicon.
Old Oct 24, 2008 | 08:07 AM
  #46
Sethco's Avatar
Borrowed from Northridge 4X4
Originally Posted by http://www.northridge4x4.com/proddetail.php?prod=CE-9807
The RockJock® JK off road suspension system allows for efficient clearance of up to 37" tall tires (with minor trimming) on any model of the 2 door or 4 door Jeep JK Wranglers. Kit allows for up to 11" of rear wheel travel and 9 1/2" of front wheel travel when used with the recommended shocks. Up to 11" of front travel is attainable when used with specific shocks and some minor trimming to the vehicle. This kit is comprised of only the highest end components in the areas of strength, fit, finish, function, and the R&D testing to back them. Included is the set of 8 Johnny Joint adjustable control arms, set of 4 lifted coil springs, front urethane bump stop kit, rear bump stop spacers, rear coil spring retaining kit, front D.O.T. approved stainless braided extended brake line kit, rear D.O.T. approved stainless braided extended brake line kit, front trac bar relocation kit, rear trac bar relocation kit, relocation kit for the tops of the front shocks, relocation kit for the bottoms of the rear shocks, rear sway bar extended links with heim joints (for use with stock rear sway bar), and a dropped pitman arm. OPTIONS NOTES: Sway bar upgrade options are available - but not included in this kit. Offered are front and rear Antirock® sway bar kits, front heim jointed adjustable sway bar links for use with the stock front sway bar, or JKS front sway bar disconnects. Shock options (sold seperately) are Rancho 9000X or 3 different styles of Walker Evans.
Do they come with new gears to maximize performance and make a smooth ride at 70 mph? I mean since you mentioned about handleing and how you wont get maximum performance or ride out of this lift. I think we should look at what it takes to get it completely lifted and maximum performance and ride. I think with your logic they should come with new axel's, gears, computer reprogrammer, front end alignment, and everything else you should do after lifting to make it complete other wise I dont think your lifts are complete.
Old Oct 24, 2008 | 08:13 AM
  #47
Robar's Avatar
Do they come with new gears to maximize performance and make a smooth ride at 70 mph? I mean since you mentioned about handleing and how you wont get maximum performance or ride out of this lift. I think we should look at what it takes to get it completely lifted and maximum performance and ride. I think with your logic they should come with new dana 60's 5:13 gears, computer reprogrammer, front end alignment, and everything else you should do after lifting to make it complete other wise I dont think your lifts are complete.
Are we talking about suspensions or drive train? I thought this thread was about suspensions.
Old Oct 24, 2008 | 08:17 AM
  #48
wayoflife's Avatar
JK-Forum Founder
new gears, computer programmers and axles? ummm, i thought we were talking about "suspension" here but, whatever.
as far as front end alignments go, you can do this yourself with the right components. need i say, with this kit and with its lack of components to do an alignment, the most you or an alignment shop can do is recenter your steering wheel and take your money.
Old Oct 24, 2008 | 08:26 AM
  #49
wayoflife's Avatar
JK-Forum Founder
4X4OPTIONS NOTES: Sway bar upgrade options are available - but not included in this kit. Offered are front and rear Antirock® sway bar kits, front heim jointed adjustable sway bar links for use with the stock front sway bar, or JKS front sway bar disconnects. Shock options (sold seperately) are Rancho 9000X or 3 different styles of Walker Evans.
okay, i see that you've edited your post.
since you seem to have missed it, i did not include sway bar links in the list of things this kit should have. likewise, being that your jeep already has a swabar, upgrading it will not make a suspension kit more complete - just different. and if you have a rubicon, you DO NOT need to upgrade anything at all. as far as shocks go, it is an option not included with the kit because most people don't like the idea of being forced to buy a set of no name brand hydro shocks that they'll just end up throwing in the trash anyway. but, you have me there. the currie kit doesn't come packaged with crappy shocks and that would make it incomplete.
