ICON Impact Series Jeep JL Front Bumper
Former Vendor
ICON set out to create a bumper that improved off-road utility by protecting critical components,
improving approach angle, and providing ample room in the fender well area for suspension
articulation and accessory function. In typical ICON fashion our engineers also developed a
bumper that could easily be customized to suit different tastes or needs with the addition of
optional Mid and Full-Width Wing Kits.
ICON IMPACT Series Off-Road Armor is built with a blend of trail-worthy ruggedness and l
ightweight performance in mind as the center section is constructed of high strength 3/16 plate
steel while the interchangeable "wings" utilize 3/16 aluminum. The included skid plate is also
constructed of 3/16 aluminum and provides exceptional protection for vulnerable OE
components while keeping overall weight in mind. A 1-3/4 x .120 wall hoop provides plenty of
space for mounting lights or accessories, while also being tough enough to take on the trail.
Many of the industrys most common accessories were considered when designing the ICON
Impact Series JL/JT front bumper, which means that it features a standard 10 x 4.5 winch
mounting plate to accept the most common aftermarket recovery systems. 1 thick steel shackle
plates meet the demands of off-road adventure and are built to accept a standard Ύ shackle.
The light pockets fit many of the industry's most popular popular 2x2 cube lights or units of
similar dimensions. The bumper is finished with a durable textured satin black powdercoat and
includes all hardware necessary for install.
To Order Today - Click Here
KEY FEATURES:
- Simple bolt-on install
- Mid and full-width wing kits available to customize bumper look & function
- Durable textured satin black powdercoat finish
- Accepts common Ύ d-ring shackles with 7/8" pin size
- Improved approach angle for off-road performance
- Increased fender well clearance for suspension articulation
- Winch-ready design includes industry standard fairlead mount and 10" x 4.5" winch mounting plate
- ICON Impact Series Limited Lifetime Warranty
- Bumper Skin Construction: 3/16 steel
- Bumper Wing Construction: 3/16 aluminum
- Winch Plate Construction: 3/16 steel
- Hoop Construction: 1-3/4 x .120 wall steel
- Shackle Mounts: 1 thick steel, 7/8 shackle pin (3/4 shackle)
- Skid Plate: 3/16" aluminum
- Unpackaged Product Weight: 73lbs (Bumper Only)
- Lighting Options:
- KC Hilites C-Series Cube Light
- Baja Designs Squadron
- Other similarly sized & mounted lights
