Hi from NJ--sagging sun visor
Old Nov 5, 2019 | 09:57 PM
jerseyboy2014jk's Avatar
Default Hi from NJ--sagging sun visor
Just bought a 2014 JK, have an issue with the passenger side sun visor....wont stay up, any tricks to fix?
Old Nov 6, 2019 | 03:38 PM
LC Boyer's Avatar
Vet Army
Welcome to our group from South Texas? I don’t know how to tighten sun visors. Did you try duct tape?
Old Nov 6, 2019 | 06:50 PM
Sunnysideup's Avatar
JK-Forum Ambassador
Is it broken... the clip that it snaps into? If not... maybe a layer of tape will help the clip grab it?
Old Nov 25, 2019 | 07:29 AM
WheelinWillyFifteen's Avatar
curious if the clip it snaps into is broken. If not I would think electrical tape would be least visible quick fix over the bar that snaps into the clip .... you can add as you need for correct tension so that the visor would stay up. I’ve read that the stock rubber around the shaft that in in the visor deteriorates. Plus I found a kit on eBay that may help. I say may help because I did not use it so I’m not a hundred percent if it would work or if it’s what you need.... it’s called the visor md on eBay it’s like 5$. Also I watched a guy use 1/4 inch washer fluid hose to wrap around it. If it’s the other piece that swings I believe you may need a new visor as i could Not find a repair kit for a Jk. I also read try tightening the screws that hold it up. That’s the best I got
