Left Tail Light
Old Oct 9, 2020 | 06:09 AM
Brian Smith's Avatar
Default Left Tail Light
My left tail light is not working. I have checked fuses, bulbs, and the connector. Everything looks okay but it does not work. Please help.
Old Oct 9, 2020 | 07:25 AM
icrashbikes's Avatar
If you have trailer wiring, check the connector. It's out in the weather and susceptible to corrosion. The wiring ties in with the taillight and a short there can mess the lights up.
Old Oct 13, 2020 | 07:44 AM
I looked at the connector, and it got loose and ended up melting onto the exhaust muffler. Is there a good forum about bypassing the wiring harness, and just make the wiring go straight to the tail light?
Old Oct 13, 2020 | 10:06 AM
karls10jk's Avatar
Are you certain it isn't the wiring harness for the trailer wiring that's on the muffler? I don't recall my harness going down that direction but the trailer harness does. You could easily unplug it, replace the harness ($20 online) and save yourself quite a bit of headache.
Old Oct 14, 2020 | 02:56 PM
It is the trailer harness that melted, i will check it out! Thank you very much
Old Oct 14, 2020 | 03:42 PM
UPDATE: Fixed it, just unplugged the trailer wiring harness and connected the tail lamp without it! Worked like a charm!
Old Oct 14, 2020 | 04:42 PM
karls10jk's Avatar
Well you're in good shape then- buy another trailer harness and make sure you tie it up tightly.
