3.6L "Chirping" noise = Water Pump
My 2013 Wrangler w/ 13,000 miles has been making a "chirping" sound from the front of the engine after it warms up. Originally I thought it sounded like the alternator bearing might be going. Took it into the dealership yesterday and they told me it was the water pump. They had replaced a couple alternators before they figured out it was actually the water pump. Apparently it's been common on the 3.6L.
Just wanted to give everyone a heads up if they start hearing a chirping noise. |
My chirping sound was the throughout bearing at 3k miles. 2014 JKR Rubi. Very common clutch issues. I have not heard much about water pumps. Thanks for info.
Originally Posted by JurassicJeep
(Post 4130289)
Hmm. I'm chirping now and I've noticed some slightly higher engine temps. Guess I'll find out Friday morning on rubicon
2012 jku. Dealer replaced mine as drivetrain warranty. Said the bearings in them were a common problem.
see pst below
Jeep JK Pully Electric Whine
Jeep JK 3.6 2012. Replaced water pump, 2 idler pulleys, x2 belts <1yr, still get this high pitched electrical sound after driving 10min moderate hills <45mph. Engine does not overheat ~110—120deg. No codes or lights, drives fine, insanely annoying |
Originally Posted by bpittman
(Post 4336211)
https://youtu.be/2jLEG1u0RnI Jeep JK 3.6 2012. Replaced water pump, 2 idler pulleys, x2 belts <1yr, still get this high pitched electrical sound after driving 10min moderate hills <45mph. Engine does not overheat ~110—120deg. No codes or lights, drives fine, insanely annoying |
It was the crankshaft pulley
did you ever figure out what it was? Mines doing the same thing now[/QUOTE] |
