3.6L "Chirping" noise = Water Pump
Old 08-05-2015, 01:53 PM
JurassicJeep's Avatar
Default 3.6L "Chirping" noise = Water Pump
My 2013 Wrangler w/ 13,000 miles has been making a "chirping" sound from the front of the engine after it warms up. Originally I thought it sounded like the alternator bearing might be going. Took it into the dealership yesterday and they told me it was the water pump. They had replaced a couple alternators before they figured out it was actually the water pump. Apparently it's been common on the 3.6L.
Just wanted to give everyone a heads up if they start hearing a chirping noise.
Old 08-05-2015, 05:53 PM
BadBry's Avatar
My chirping sound was the throughout bearing at 3k miles. 2014 JKR Rubi. Very common clutch issues. I have not heard much about water pumps. Thanks for info.
Old 08-05-2015, 07:51 PM
lulu2533's Avatar
Yep. Had the "chirping noise about two years ago on my '13. After a few trips to the dealership without resolve, they finally replaced the water pump. I originally told them that was the problem but of course they did not listen to me. I found out through this forum, I think, and watching a video that was posted.
Old 08-05-2015, 08:00 PM
orangedude71's Avatar
Hmm. I'm chirping now and I've noticed some slightly higher engine temps. Guess I'll find out Friday morning on rubicon
Old 08-06-2015, 04:55 AM
jk1975's Avatar
2012 jku. Dealer replaced mine as drivetrain warranty. Said the bearings in them were a common problem.
Old 02-12-2019, 06:00 PM
bpittman's Avatar
see pst below
Old 02-13-2019, 06:26 PM
bpittman's Avatar
Default Jeep JK Pully Electric Whine
Jeep JK 3.6 2012. Replaced water pump, 2 idler pulleys, x2 belts <1yr, still get this high pitched electrical sound after driving 10min moderate hills <45mph. Engine does not overheat ~110—120deg. No codes or lights, drives fine, insanely annoying
[/QUOTE]
Old 08-12-2021, 09:53 AM
Ksundys12's Avatar
Originally Posted by bpittman
https://youtu.be/2jLEG1u0RnI
[/QUOTE] did you ever figure out what it was? Mines doing the same thing now
Old 08-12-2021, 09:58 AM
bpittman's Avatar
It was the crankshaft pulley
did you ever figure out what it was? Mines doing the same thing now[/QUOTE]
Quick Reply: 3.6L "Chirping" noise = Water Pump
