Drive shaft hitting gas tank skid
Old Nov 18, 2013 | 03:55 AM
JKZinger's Avatar
Originally Posted by HOGGSTATUS
You don't have a axle side Track bar bracket? I didn't look, but if you don't that is most of the problem! Due to your lift a stock track bar would pull the axle toward the passenger side....causing that drive shaft to rub!!
X2 on this. The lift should have come with an axle bracket to keep things in line.
Old Nov 18, 2013 | 04:40 AM
familytime's Avatar
JK Forum Regional Rep
A bracket will help here also a lot less expensive than a new adjustable track bar
Old Nov 18, 2013 | 06:38 AM
spinuck's Avatar
The lift I have ( teraflex 4inch long arm) came with a rear track bar bracket. It has 3 holes for mounting position, right now it's in the top most spot. I tried measuring, and it doesn't appear to be off center.
