Rock guards
Old Aug 15, 2012 | 06:47 PM
Linemanwife's Avatar
Default Rock guards
Still looking for advise on brand and why! I got permission from the hubby to go shopping. Need help please.
Old Aug 15, 2012 | 08:06 PM
Stuka's Avatar
I stand by EVO's being the best. But they are weld on. So once they are there, they don't easily come off.
If you want cheap you can get some stock rubicon take offs (Well unless you already have a rubi).
There are plenty of bolt on ones as well. Just stay far away from any that attach to the body and the frame. And frame mounted ones are the strongest. Body mounted ones are fine for light usage.
Old Aug 15, 2012 | 08:29 PM
JKZinger's Avatar
I have the Ace bolt ons that bolt onto the 3 body mount bolts. I have hammered the hell out of mine and they are great. If I was to do it again though, I would get the EVO's and weld them on. They will give you a little more clearance.
Old Aug 15, 2012 | 08:37 PM
PharmNip's Avatar
If you aren't welding them on get the ACE rails, you can't beat the price and quality and you can put them on with the rubi rails. EVO rails are in the same class with ACE, really comes down to a weld preference.
Old Aug 15, 2012 | 08:39 PM
Huckleberryjeep's Avatar
im a fanboy
i love the look and function of the ace
Old Aug 16, 2012 | 02:33 AM
EzK's Avatar
EzK
Poison Spyder: heavy duty, look fantastic
Nemesis: Aluminum multi piece guards that I'm currently obsessed with but they are pricy.
Give these a peak if you have coin to spend and want to avoid the welding.
http://www.nem-ind.com/catalog/jk/jk...-kit-jk-4-door
Old Aug 16, 2012 | 03:23 AM
fadeout's Avatar
No Evo's are in a whole nother class. I've seen ACE flex the rubi rails up and create a ton of body damage. They will flex and they will cause body damage either with one good hit or mildly over time. This will not happen with the EVO or any other Frame mounted slider.
Old Aug 16, 2012 | 03:44 AM
EzK's Avatar
EzK
Man, that had to be a ridiculous slam to push both up into the body. Ouch.
Old Aug 16, 2012 | 05:37 AM
Duradak's Avatar
X2, …with emphasis on ‘ridiculous’!
Old Aug 16, 2012 | 09:09 AM
fadeout's Avatar
It was just one of those hits, the damage on the ace rails was only a dent about 4-6 inches in length, they were still usable but the way they pushed up with the rubi rails is where they deformed the lower rocker portion of the Jeep. cracked the paint and bent the body.
