Who's up for a ball joint install party?
#92
Former Member
Probably is your unit bearings especially since you just changed the ball joints. You go with Timken or SKF? At least the price for replacement isn't extremely crazy.
#96
Former Member
Former Member
changed driver's side wheel bearing. didn't change passenger side since there's no play in the wheel. put the front tires on rear, and still get vibrations between 40 and 60. Going to have tires balanced again. if that doesn't work, going to pull front drive shaft and see if that's it. going to recheck toe-in. not sure what else to check.
#100
