Have a large wire crimper and wanna help a guy out?
Old Oct 18, 2012 | 05:56 AM
ChrisJ's Avatar
Default Have a large wire crimper and wanna help a guy out?
I'm trying to hook up my winch and just picked up some welding cable, terminals, heat shrink, etc. What I don't have is a crimper that will work on 2 AWG cable. I could go buy one, but spending $60+ on something I will use for 2 minutes isn't really in the cards right now.
Anyone in the Renton-ish area have one that I could use? There could be a 6-pack of your favorite beverage in it for you.
Old Oct 18, 2012 | 06:29 AM
fatboy044's Avatar
I got some but I'm a little farther then reasonable, I'd try calling your local shucks orielly they have a great tool rental policy. Most items they rent, you put a deposit down that you get back when you return them making the rental free, I did that with their coil spring compressors before. Good luck
Old Oct 18, 2012 | 07:50 AM
ChrisJ's Avatar
Yeah, I've done that before with a spring compressor, but I didn't figure they'd have this sort of thing. I'll give it a shot. Thanks!
Old Oct 18, 2012 | 07:56 AM
GKR's Avatar
GKR
I have a hammer crimper you can use if you like. I'm in Kent.
Old Oct 18, 2012 | 10:55 AM
Freewill's Avatar
Why not use solder? Easy to do in the field, makes a continuous connection, plenty strong. Easy to practice the skill - just buy a few cheap 1/2" copper pipe fittings and a couple feet of pipe and sweat solder them together. Same technique as sweat soldering big lugs onto cable. If you've never soldered, there hasta be a youtube video out there.
You need a propane torch, a roll of old-fashioned lead/tin solder, some soldering paste, and some 100 grit Emory cloth. Use a strong solvent to clean any excess paste off when finished. It contains some acid. I've never had it cause a problem but still like to clean it up.
If you have a heat gun, some heat shrink over the connection makes a nice job. Tape works also. (This applies with soldered or crimped lugs.)
Old Oct 18, 2012 | 06:47 PM
ChrisJ's Avatar
I ended up just picking up some crimpers, but I appreciate the offers and the advice!
Side note, the hydraulic crimp tool sold at Harbor Freight is pretty damn nice.
