Tie Rod swap
Old Apr 10, 2011 | 11:26 AM
nwbronco's Avatar
Default Tie Rod swap
Well, I got the replacement Currie Tie rod form Dave at Northridge. I must say the rod ends on this thing are almost twice the size of the stock ends. The replacement took a couple of hours. I think I'll end up taking it in for an alignment.
Here's the damage done at Tahuya...
The stock tie rod laid out next to the Currie one...
There is a night and day difference in the Currie Tie Rod. Note: Make sure you have a grease gun when you install this. There are grease fittings on the ends and it needs grease.
Installed product.
A little side poject. Pulled the front and rear carpet. Hung them over the trash can, and the water ran out....
I wil run without them for a while. And hang them in the garage to completely dry out.
A good Saturday. If your not wheeling, your wrenching.
Bob K.
Old Apr 10, 2011 | 11:35 AM
jsears's Avatar
Wow, there is quite the difference between the stock and Currie tie rods!!
Old Apr 10, 2011 | 11:57 AM
dcirate25's Avatar
How did you know you needed new tire rods? I keep hearing a slight knock when I'm stopping and was wondering if it was them.
Old Apr 10, 2011 | 12:49 PM
nwbronco's Avatar
Tie rods were okay. I liked the Currie setup and decided to upgrade as I replaced the tie rod. The clunking could be your tie rod/drag link ends. Check them out.
Bob K.
Old Apr 10, 2011 | 02:52 PM
zeppo's Avatar
Looks good there. Like I said at the end of the day, it's a vicious and glorious cycle of upgrading, playing, breaking, and upgrading. Sometimes I look forward to little problems like that one so I have a good reason to upgrade something. Some would call that an excuse but I think it's the best reason in the world for an upgrade.
Old Apr 11, 2011 | 06:28 AM
nwbronco's Avatar
Thanks. I honestly think that I steered the bend in that tie rod. I do not remember backing up in the section of the rocks. And the bend happened there. You are correct. Damage to stock parts is always a good reason to upgrade. With the JKUs stock parts are almost as expensive as the upgrade parts. I noticed the clearance on the currie ends, they've got the engineering down to a science. It is within centimeters of the backing plate behind the rotor.
Bob K.
Old Apr 11, 2011 | 07:55 AM
Garyyth's Avatar
Nice write up Bob, looks good. Hope to see it in action on the trails soon
Old Apr 11, 2011 | 10:08 AM
nwbronco's Avatar
Most definitely. I need to run it up to a shop and get an alignment done. Trailworthy right now. I do need to go through it after the missus U-boat adventure.
Bob
