Scale models and R/C hobbies Share your scale models and other radio controlled hobbies with the JK-Forum community!
What was done on your R/C this week???
Old 12-08-2013, 05:11 PM
JK Forum Regional Rep
familytime's Avatar
ID:	515608Got some new shoes with some beadlocks
Old 12-16-2013, 10:59 AM
Enclocal's Avatar
SCX10 JK RTR
deans adapter
2S 35c 7.4v 5000mAh lipo batt
batt charger
Axial Hi-Clearance Knuckles
Aluminum C Hub Carrier
Universal Set AX10
Body Clip 6mm Black (10)
Blue Money Stage 1 Titanium Link Kit for SCX10
Juncs Hardened Universal Shaft for Axial
EcoPower "Electron" 2S Li-Poly 30C Hard Case Battery Pack (7.4V/5000mAh
RC4WD Mickey Thompson "Baja Claw TTC" 1.9 Scale Tires (4)
Axial 1.9 8 Hole Beadlocks (Black) (4)
Hitec HS-7950TH Programmable High Voltage Ultra Torque 7.4V Servo Titanium Gear
Castle Creations CC Bec 10A 6S Switching Regulator
Castle Creations Castle Link USB Programming Adapter by Castle Creations
Aluminum Servo Horn 24T
Hot Racing SCX28301 Aluminum Fr & Re Shock Tower
Pro-Line Powerstroke Scaler Shocks 90mm-95mm (dual rate)
Robinson Racing Hard Steel Idler Gear AX10 #1541
Robinson Racing Hard Aluminum Diff Gear For AX10 #15
Old 01-03-2014, 02:22 PM
Grubbicon's Avatar
Cut the back half off the cage and cut the top and put a 45T motor in (forget what the name is probably
should of payed more attention but for $30 i recommend it)
Old 01-04-2014, 03:22 PM
Grubbicon's Avatar
Put a Vanquish 10 link set on my wraith
Old 01-04-2014, 04:24 PM
familytime's Avatar
ID:	521269Click image for larger version
ID:	521270Click image for larger version
ID:	521271Finished my cargo rack,picked up some goodies for the rack,also got my servo winch,35t Holmes Expert motor,junfac driveshafts
Old 01-05-2014, 02:58 PM
familytime's Avatar
ID:	521619Made some sand ladders
Old 04-06-2014, 11:20 PM
Endocrash's Avatar
Gonna get the thread rolling again. Started waterproofing my rig. Did the rear shock relocation, love the flex! Converted the front 3 link to 4. Axial beadlocks with BPC weights. BPC battery tray. Props go to Familytime once again for the matching BPC skids. Wired in the CC BEC. Oh, and made some tow straps! Busy week, LoL
ID:	543855   Click image for larger version
ID:	543856   Click image for larger version
ID:	543857   Click image for larger version
Old 04-07-2014, 10:11 AM
EmptyPocketsRubicon's Avatar
I have the same rig, I would like to know more about the waterproofing.
Old 04-07-2014, 01:45 PM
Grubbicon's Avatar
if you want to waterproof follow this
http://youtu.be/SzmK_tvbejE He gives detail and goes over everything front to back. Just remember it will help keep water out but you still have risk of water getting in
Old 04-07-2014, 04:17 PM
familytime's Avatar
Looking good
Quick Reply: What was done on your R/C this week???
