Old Sep 27, 2009 | 07:34 PM
  #6661
mkjeep's Avatar
What happened to your control arm bolt??
Old Sep 27, 2009 | 07:48 PM
  #6662
JeepNumber5's Avatar
Default Rock Hard Rear Bumper/Tire Carrier installed!
Very impressed with the finished product!
(I'm the guy on the left.)
Old Sep 28, 2009 | 04:01 AM
  #6663
davegus's Avatar
yeah, that's the question! Odd thing is I had that lift installed by a well-known 4 wheel parts and service company, and had it retorqued as required. So, you can imagine my surprise...
Old Sep 28, 2009 | 08:06 AM
  #6664
rbuckenmeyer's Avatar
garage door opener hard wired with hidden button.
Name:	garage door opener.jpg
Old Sep 28, 2009 | 06:52 PM
  #6665
BIGJ's Avatar
Talking
finally got new rear bumper w carrier, amd my new I-Rack from SB, and i am likin itClick image for larger version
Old Sep 29, 2009 | 07:01 AM
  #6666
mscedro2's Avatar
Originally Posted by Geeper4x4
I know it is kinda backwards but I put on my CB mount/antennae and ran the cable. I will get the CB later ath the local Wally world. He has really nice equipment but I won't spend that much for the CB itself. The CB shop I use isn't open weekdays late enough for me to get to. So the antenne was better for my schedule. I made a mount from some scrap metal in the garage and mounted it behind my spare. It is a 4' Wilson flexible which is a great antenne that bends easily on the trail. The cable was a 18' length because of the 4 door. I found this to be a better location for the trail and street.
I have a Radio Shack hand held with weather alert. I have great reception with the hand held on the trails, but would like to add an external antennae for increase range. Your antennae mount location is where I will mount mine...the oppisite location is used for a trail flag mount. Question: Did you route your CB antennae cable thru the rear third light wiring grommet? If you have a pic of the grommet, it will answer my question . Great rig by the way.
Old Sep 29, 2009 | 07:47 AM
  #6667
ssmathis's Avatar
Last Thursday I had a seal replaced on the engine for leaking oil, only 14k miles so far, and then yesterday I had the radiator cap replaced as it started leaking.
Scott
Old Sep 29, 2009 | 01:47 PM
  #6668
ben1284's Avatar
New jks adj. trackbar. FROM WWW.NORTHRIDGE4X4.COM ......it's night and day difference from the stocker that was on there....steering is not near as flighty as it was b4.
not a "fun" purchase, but if you're you're driving around w/out one and ure rig is lifted and has bigger tires, i would definately recommend purchasing one. just get it over with cause i can definately tell a difference
Old Sep 29, 2009 | 01:50 PM
  #6669
hassara's Avatar
Default Installed a mount for my Hi-Lift Jack and a MOLLE tailgate cover
I just installed a Hi-Lift Jack mount. I'm very pleased with the results. There are no vibrations from it.
Also, I installed a SmittyBilt G.E.A.R. Tailgate Cover. The cover is MOLLE compatible (that's a US Gov't term for MOdular Lightweight Load-carrying Equipment). You can get all kinds of other packs, pouches and containers online or from military surplus stores.
I have one on order that puts a MOLLE console from the A column to the B column.
Old Sep 29, 2009 | 02:25 PM
  #6670
Lo2aY's Avatar
Got the rings blacked out
