2 Inch Lift - Noise over bumps
I've got the 2 inch FT lift, M-Force shocks, and the front FT Adjustable track bar - all else is stock. Overall - lift is perfect for my needs and it actually drives (much) better than stock.
BUT after a couple weeks, I have a deep 'squeak' coming from (I believe) the front when going over bumps... Drives fine, and I've been underneath and everything looks good - no noise when phsyically pushing down on the suspension.
Anyone else experience this? Could it be the bushing or spherical joint on the adjustable track bar? Thanks!
Its the bushing/sleeve. You have to take it off and grease it. I have the same issue. I thought I read where someone put a zerk fitting on theirs so they wouldn't have to drop that side just to grease it. I would imagine that you would have to drill all the way down through the sleeve to do it.
Should have done a better search before posting - looks like it's already covered on this post:
https://www.jk-forum.com/forums/show...ghlight=squeak
White Lithium Grease every few thousand miles - sounds easy enough.
Thanks!
Thanks!
Thanks!
Thanks!
http://project-jk.com/jeep-jk-write-...ation-write-up
Actually WOL, i had greased on install inside and out, and alos took the bushingout 2 different times to re grease and the noise kept coming back.
So i added the grease zerk to the TB back in July and have not had a aqueak again. I am very happy with my mod and would do it again and recommend it to anyone.
