Jeeper asking for help
I need someone to help me set up my gears in my dana 44. I have done gears in the past and no problem. However for some reason I can not get these to set up right.
I well have everything apart. I even have the bearings shaved out to help with quick shim changes. All I need is for you to come over and make sure i'm not looseing my mind on seting these up. This will be the 3rd time I have pulled this apart.
I will do all the work. you don't even have to get dirty.
Please let me know if you can help. I need this up and running by 12/28
Thank you.
I will do all the work. you don't even have to get dirty. Please let me know if you can help. I need this up and running by 12/28
Thank you.
