esp on 2" lift
Old Sep 8, 2009 | 01:04 PM
wrangler08jk's Avatar
Default esp on 2" lift
Not sure if this is the place to ask this question,but here it is. I recently installed a 2" FULL TRACTION SPACER LIFT ON MY 08 UNLIMITED. I took it for a spin and my esp kept coming on at very slight turns. My steering wheel was a quarter turn but going straight. I got my front end realigned and the esp came on once. Is there something else I need to do since the install.
Old Sep 8, 2009 | 01:09 PM
Dan415's Avatar
Default Esp
Hey,
Yea happens usually on a gradual turn, esp comes on and tries to break for you. There is a fairly lengthy thread here somewhere on the subject. Some say a flash to the computer will help, some say their esp cable is rubbing etc. Ive only had it looked at by 1 dealer and they told me "Tough shit you lifted it, here is an instruction sheet how to disable the ESP" ... so yea I can disable it but its not a perm. solution.
lookup the 'basic do-it-urself jeep jk wrangler front end alignment' on project-jk.com... most say that works
Old Sep 8, 2009 | 01:28 PM
Robar's Avatar
Sounds like you need to recenter your steering wheel. It's pretty simple to do and only takes a 15mm socket or wrench.
https://www.jk-forum.com/forums/show...90&postcount=7
Old Sep 9, 2009 | 02:44 PM
Thank You for your input. It seems that the problem is fixed at this moment. Now for bigger tires.
Old Sep 9, 2009 | 03:17 PM
Mr.ZAP's Avatar
That is really weird cuz I have the same lift and have never had that problem
Old Sep 9, 2009 | 03:39 PM
Robert's Avatar
Default Ymmv
Seems like these smaller lifts vary a lot. I have a 2.5" with no problems, but I hear many other have to install worlds of extra gear to avoid death wobble and various other problems.
At least the problem was solvable.
Old Sep 9, 2009 | 04:14 PM
JKRockStomper's Avatar
Just adjust the Front Trackbar. You will need a 15mm wrench or socket to loosen the trackbar adjuster.
