Auto tranny pan
Old Sep 12, 2009 | 03:45 PM
dblhelx's Avatar
Default Auto tranny pan
Are there any aftermarket auto tranny pans that come with a drain plug?
Old Sep 12, 2009 | 03:53 PM
mkjeep's Avatar
Not that I know of, but you can drill and tap your own.
Old Sep 12, 2009 | 04:22 PM
ronjenx's Avatar
A new pan from the dealer is cheap. Drain plugs are cheap. Get both and have a shop weld it in for you. There is even a low spot in the pan where the factory SHOULD have installed one.
Name:	Drain Plug Location.jpg
Old Sep 12, 2009 | 04:43 PM
Jiblet's Avatar
nice graphic! how does the temp sensor communicate with the ECU? is it a sending unit?
Old Sep 12, 2009 | 05:01 PM
ronjenx's Avatar
I installed the temp sensor and wired it to a gauge upstairs.
That was before I knew about the AeroForce gauge, which I have now. I still use the temp gauge, though.
Old Sep 12, 2009 | 06:13 PM
Jiblet's Avatar
Got it. Thanks. I thought the temp sensor in your photo was stock or something.
How do your temp sensor readings compare with your Aeroforce readings?
Old Sep 12, 2009 | 07:13 PM
ronjenx's Avatar
The installed gauge reads about a needle width cooler than the AeroForce gauge. Could be because the factory sensor is higher in the sump, inside the valve body.
