rim spacers and 35" tires
Old Sep 14, 2009 | 09:17 AM
Default rim spacers and 35" tires
i know i need the spacers on the stock rims if i go to a 35x12.5 tire but if i by new rims can i fix this problem by changing the back spacing. if so what would be a good back spacing for a 10" wide 16" rim
Old Sep 14, 2009 | 10:40 AM
nthinuf's Avatar
Start in the Wheels & Tires area of the FAQ. It's stickied at the top of this modified section...
https://www.jk-forum.com/forums/show...74&postcount=3
Old Sep 14, 2009 | 11:05 AM
thanks alot. those q/a's are great. it explains the difference between back spacing and offset and states the back spacing for all stocks to be at 6.25" if i remember but it doesn't say what the off set is. does anyone know the off set or is there even an offset.
Old Sep 14, 2009 | 03:00 PM
horwitzs's Avatar
Don't worry about your offset,
just make sure you buy rims with 4.5" backspacing or less.
See, it takes even less effort to answer the question than to berate you and make you go look someplace else without any more info that you had when you asked... wow!
Old Sep 15, 2009 | 06:19 AM
Originally Posted by MarcusRTJ
Yeah alright but do you know how monotonous the posts get on this forum? Its the same thing EVERY SINGLE DAY.
Maybe I'm just getting frustrated and need to take some time off.
i under stand what you're saying with the same questions but searches seem to be inaccurate and horwitzs is right in what he said
