Simple way to have Lockers in 4Hi?
On my TJ there was a simple bypass so you could run the lockers in 4Hi. Has anybody figured out how to run the stock lockers in 4Hi on a JK Rubicon yet?
Thanks,
Flash
Thanks,
Flash
The tuner only allows you to run one locker locked in 4Hi and the tuner has to be connected while you do it. In other words, a pain in the a$$ to use. We need a permanent solution.
Flash
Flash
I did this mod and haven't had any problems.
https://www.jk-forum.com/forums/jk-write-ups-39/rubicon-owners-locker-modification-88085/
