Steering stabilizer?
Old Sep 25, 2009 | 11:14 AM
jmow01's Avatar
Default Steering stabilizer?
Just installed 2.5bb w/adaptors and 35s at highway speeds my jeep wonders like crazy!!! Do I need an aftermarket stabilizer or do I have other problems? Thanks for your help!!!!
Old Sep 25, 2009 | 11:17 AM
chickenman's Avatar
do you have any other mods? Could be a combination of things...
Old Sep 25, 2009 | 11:20 AM
spinlock's Avatar
Double check your alignment angles, particularly Caster (the mother of stable tracking).
rinkishJK's Avatar
did you fix your alignment after lift??
Old Sep 25, 2009 | 11:22 AM
jmow01's Avatar
Nope... I ran the lift for about a week before the rims/ tires. It was fine... Went with a wider rim/tire...?
Northridge4x4's Avatar
Sponsoring Vendor
You need to get some front adjustable control arms to fix the castor and that will solve your problem.
Old Sep 25, 2009 | 11:26 AM
jmow01's Avatar
Well I went with the BB so I would not have to get all that good stuff... If I knew that was needed I woulda went for 4"!!!
Old Sep 25, 2009 | 11:35 AM
jmow01's Avatar
Is that the final answer?
Old Sep 25, 2009 | 11:50 AM
Sponsoring Vendor
Of course not you can get cam bolts if you want I would not recommend that though.
You can get a steering stabilizer and it will help a little bit.
You also will want to check air pressure in your tires, make sure they dont have 50 psi and they are all the same.
David
Old Sep 25, 2009 | 12:15 PM
jmow01's Avatar
Sounds good! You may be getting a call very soon... I've been ordering my stuff from somewhere other than northridge and I think that may have been a mistake!!
