2 inch swaying jk
I was wondering if anyone can tell me if this is normal? I put a 2 inch fulltraction spacer kit on my 08 unlimited. I took it down to the beach on some back country roads and most of the time going over a hill with a slight turn it felt like it was swaying. Now i did have the back packed with 3 suitcase but not a whole lot of weight do i need stiffer or better shocks. It took a little to adjust but wondering if this is normal. I had a tj with 2 inch spacers but it did not do this. Any help would be appreciated
Thanks to all! Looks like a longer sway bar links and shock extensions are nest on the list. Wheel spacerwas a thought but waitying to get new rims and tires and see what backspacing i get.
I used to have the FT budget boost on mine and I didn't notice any change in handling like you're experiencing. I did have a good bit of bump steer from the track bar relocation bracket so I removed it and got rid of the bump steer. Might try that if you have it installed.
