Regearing JK Rubicon
Hi. I want to regear my JK Rubicon with 5.13 gears. I haven't found a webshop that has offered both rear and front gearings and overhaul kits. Any suggestions?
Can I use the same overhaul kit front and rear? I have understood that the Rubicon gearings are diffrent, compared to stock D44 gearings.
Stein, No(r)way
Stein, No(r)way
You can get them from Northridge4X4, Quadratec and a few other places.....check them out, they have everything you need to get it done...complete overhaul kits, or basic install kits...depends on your application....ie amount of miles on your rig.....
I just went to Superior 513 in mine.....I love it
...to me the mod is completely worth it...specially if you have 35's or larger.....cheers
You can order them from any shop, but here is the link to the gears at Northridge, since I had it handy.
http://www.northridge4x4.com/products.php?cat=277
Select one of the front/rear packages, and there is a pulldown for you to enter which model you have so you're sure to get the right gears for your Rubi.
It might be a bit on the costly side for you to call them, but they are a sponsor here, so you can send a direct message to get more info if you need to.
