Whats the diff between rock guards and sliders
Old Sep 29, 2009 | 04:06 PM
mattyhfd's Avatar
Default Whats the diff between rock guards and sliders
i like certain rockers and i like certain sliders but idk what their differences are. what are the 2 meant for
Old Sep 29, 2009 | 04:43 PM
Suffolk JK's Avatar
If they bolt to the frame and/or body and are meant to be abused, they are rocker/rock sliders. Meant to protect the sides of the body. They can help by not causing you to come down onto the body when coming over an obstacle (ie. rock). Or, they can keep you away from obstacles when going around them (ie. rock) so you won't come in contact with the body (ie. doors). Come over and take a look at mine. You need them.
Old Sep 29, 2009 | 05:35 PM
horwitzs's Avatar
Tomato & tom-ah-to.
Old Sep 29, 2009 | 05:37 PM
RedneckJeep's Avatar
Originally Posted by horwitzs
Tomato & tom-ah-to.
Pretty much.
Old Sep 29, 2009 | 06:53 PM
CIJeep's Avatar
Technically sliders slide over the rocks, protects the bottom of the vehicle and some body protection. Usually closer to the body and cannot be used as a step.
Rockers a lot like above plus side protection from rocks, trees etc on you rocker panel. It can be used as a fulcrum point to hold tight to a tree or rock while you power your Jeep around it like a pivot point.
In reality it is getting pretty blurred.
It also means making a hard choice, do you opt for getting your fat body stuck between boulders or tree's or do you get.keep all skinny and drive through.
