Need help
Need help
Tomorrow I will start my install on my lift kit. I ordered a teraflex 3" with front lower FlexArms and rear upper FlexArms. Can anyone tell me the measurements for these flex arms. Thanks for the help.
Your kit will come with a sheet that tells you TFs recommended lengths. Also look at the project-jk write up. I used the project jk measurements as my staring point, had to do some minor tweaking to get my caster, driveshaft angle, etc. set.
Not sure if you have a 2 or 4dr JK, but below is the info taken from TeraFlex for a 4dr...
Front Lower
Driver side = 23 7/8"
Passenger = 24 1/8"
Rear Uppers
Drivers & Passenger = 18 3/8"
Front Lower
Passenger = 24 1/8"
Rear Uppers
