Need a solid answer
Old 10-23-2009, 10:08 PM
Michiguy's Avatar
Default Need a solid answer
I hate to beat this to death if it has already been asked. I TRULY APOLOGIZE IN ADVANCE.
I have a Sport, 3.73. Auto trans.
Can I run 285x75R17 (32.7" actual height tires) BF Goodrich ATs without doing damage?
What else will I need? Will I need a trans cooler or do I not need one?
Old 10-23-2009, 11:07 PM
marcoseddi's Avatar
Default Alll good
i got 33's with 3.21 working perfect i put wheel spacers 1.5 no rubbing er ripped of air dam under the bumper stupid item and nothign although when im aking really sharpper turns comin off excit for example and coming around tofast the tires sort of lock up but your good to go no other issues at all its
Old 10-24-2009, 06:57 AM
nthinuf's Avatar
Yes, you can run that size. It is a bit taller and wider than stock, as you know. At full lock either way, you may rub a bit. Nothing some minor trimming or a bit of steer stop adjustment won't fix. (or get some spacers)
Only you can decide if you are happy running a particular tire size on your stock gears. (my opinion - auto's are under-geared/under-powered from the factory)
Trans coolers cost what, $45? Why would you not get one, regardless of going to a taller tire...
Quick Reply: Need a solid answer
