BL--- any issue i must knew before install?
i´m waiting for a 1" Body Lift and a AEV Snorkel.
is it necesary to disconnect the batery before lift the body?,..
i had read that it´s necessary to disconnect the batery to avoid problems with the airbags.
Otherwise, i´m thinking that there would be a little gap between the grille and the front bumper, isn´t it?
1 Post
As a general rule it is normally wise to disconnect the battery before doing much of any modifying on a vehicle, anything electrical is a no brainer, but when your messing with the frame (or anything else that MIGHT have a ground strap nearby) the extra minute and a half (if that) to disconnect the battery is just plain worth it.
