XRC 10 winch not working
Help !!!
I attempted to install my brand new Smittybilt XRC10 winch tonight....
I have no power to it. The manual lever does not work. When the remote is plugged in, nothing works and the in/out lights do not even light up. I am able to free spool the line out.
The install instructions I thought were pretty hard to mess up...and I have done the following things..
1. Rechecked all wiring to make sure it is in the proper place (it is all color coded and labled)
2. Rechecked battery terminals for tightness and making sure + to + and so on.
3. All other accessories mounted to the battery are working fine.
4. The main ground is direct to the battery.
Below are pics of the instructions and the wiring on the back of the winch all hooked up.
HELP
HELP
it could be a ground........ If i where you I would put my ground on the Neg terminal on the battery. Just for grins and see if it works...
Should have got a WARN....
Just tease in you!
I was looking at this winch as well...but shipping to Canada was a killer...reaching the price of some Warn winches. Hope you get it figured out and once you get it working...have a
Just tease in you!
Does your remote "snap in" or just kinda "sit" in the control box. Mine just sits in there, No "click in."
yes you push in and make a slight turn clockwise. you then need to hit the little metal button to remove. if you can pull the remote plug out without pressing that button then it is not in correctly. Hope that helps
