Teraflex Question
Old Dec 3, 2009 | 05:45 PM
MENDO's Avatar
Default Teraflex Question
Just about 70-percent done on installing my 4in teraflex lift with full flex arms but ran into an issue with 1in front coil spacers. I installed the teraflex upper front bumpstop extensions before remebering to install the coil spacers. Now i can't remove the upper bumpstops to install the spacers! Anyone have any input on what to do without damaging the bumpstop extensions?
Old Dec 3, 2009 | 05:51 PM
frankie945's Avatar
a little heat should loosen it up. And a strong right hand.
Old Dec 3, 2009 | 05:57 PM
MENDO's Avatar
Would heating it up damage the rim that seats into the frame. I mean this thing is in there and havin to use a floor Jack to set it, well I just don't know
Old Dec 3, 2009 | 05:58 PM
bigbluejk's Avatar
Just grab ahold with both hands and work it back and forth till it pops out.
Old Dec 3, 2009 | 06:01 PM
Ryanc's Avatar
It will come out, just twist it a little bit.
MENDO's Avatar
Worked that damn thing back and forth for almost five minuteswith both hands and nothing
Old Dec 3, 2009 | 06:02 PM
MENDO's Avatar
It was even greased before install
Old Dec 3, 2009 | 06:05 PM
mkjeep's Avatar
Get a 35 yr old divorcee out there , she'll work that thing loose in a couple minutes.
Old Dec 3, 2009 | 06:06 PM
Gcollura's Avatar
I was able to pull mine out by working it back and forth. Spray up in there with some WD40 to grease it up and pull hard it will not hurt it.
Old Dec 3, 2009 | 06:10 PM
MENDO's Avatar
The divorcee sounds like a good option but wouldn't work out with the wifee.
I'll try the wd and try again.
Thanks guys!
