What's the interior cargo wall cover thing called...
I recently saw a pair of metal 'walls' that bolted to the same points that the hard top attached to. All they really did was cover up the interior sides of the JK cargo area in sheet metal. Once you had them installed you could then mount whatever you wanted to them.
I think they were from one of the small companies / independent people, but I don't remember who it was / what they were called...
Hmm, that doesn't seem to be them. I've seen the MPAC ones before and they require drilling to mount and already have various slots cut in them for using MOLLE straps.
The things I'm thinking about didn't require any drilling, the slide down each side and then the bolts that hold the hard top on were the same that would hold these on. They didn't have any slots/holes/mounting points pre-drilled, though their picture did show a couple of power outlets on them.
Mine arrived a couple days ago, I did my install this morning. Took some pictures as I was going.
Encountered a problem (I have an Unlimited with the soft top). I sent mail+pics off the Kilby earlier today, so I'm going to hold-off on my write-up until I get a response from them (or him I suppose)
