rubicon express vs. teraflex
Old Jan 17, 2010 | 06:27 PM
russellauto's Avatar
Default rubicon express vs. teraflex
I have a 3.5" rubicon express kit (standard kit with currie front lowers and rear upper arms, ome shocks) on my personal jk unlimited. Then I installed a teraflex 3" (standard with tera ft lowers and rr upper arms, tera shocks) for the dealership I work for. The teraflex kit rides and drives tremendously better, no flighty feeling and much softer ride. Anyone have the same experience with their rubicon express kits? I am thinking about swapping lifts on mine, the other rides/drives that much better.
Old Jan 17, 2010 | 06:29 PM
mkjeep's Avatar
Old Jan 17, 2010 | 06:43 PM
i may have a rubicon kit for sale
Old Jan 17, 2010 | 06:53 PM
Both rigs were running load E rated tires. David at northridge hooked me up with the ome shocks, so i hope they are correct. The one difference is the tera jk had +7 castor and I am running +5.7. Would there be that much difference in that? I am also running about 32 psi in my tires.
Old Jan 17, 2010 | 07:09 PM
i am not sure exact settings, but both were put back to factory specs. I also get a little bit of shimmy at about 55mph can drive through easily. I appreciate the help.
Old Jan 17, 2010 | 07:10 PM
the teraflex unit drove better, even before doing an alignment.
Old Jan 17, 2010 | 07:19 PM
the rubicon kit came with an adjustable track bar, is it decent? My control arms are twisted in the mounts, is that normal, i have loosened and re-tightened the jam nut, but they are twisted again?
Old Jan 17, 2010 | 07:23 PM
mkjeep's Avatar
Bwaahh ha haaah Aw, I'm just ribbin the RE guys
Old Jan 17, 2010 | 10:45 PM
spinlock's Avatar
In terms of ride:
Much of the improved ride is probably due to the tuned shocks/coils in the TF lift, but as Planman explained there are differences between the bushings and joint in both lifts.
Stiff bushings will make a noticeable difference on the street where irregularities on the road will cause perturbations too small for the coils to fully absorb so they gets transmitted via the links.
In terms of handling:
The flighty feeling you refer is either an alignment problem, a geometry difference created by one lift producing more lift than the other.
Either way it's an interesting comparison of the two lifts.
Old Jan 17, 2010 | 11:41 PM
captjay's Avatar
wow, what is it with people rippin on us RE guys???
