Mtrs with kevlar VS Cooper SST actual height
coopers website says:
315/75R16 = 34.47"
35x12.50R17 = 34.76
goodyear webitesite says:
315/75R16 = 34.8
35x12.50R17 = 34.8
Remember these are the heights of the tires before adding the weight off the vehicle.
315/75R16 = 34.47"
35x12.50R17 = 34.76
315/75R16 = 34.8
35x12.50R17 = 34.8
I don't know how accurate you need to know actual tire height, but it is dependent on loading (bumpers, winch, spare size, etc) and more importantly air pressure. Rim width and sidewall construction (load rating) also factor in.
My D rated KM2s listed at 34.8" tall are just 33.3" at 30 psi and 34" at 35 psi.
And they typically over state the actual height... My 35/1250/17 MT/R Kevlars measure 34.25 mounted on a 8" wheel with 30 psi. That is without the weight of the vehicle. This is pretty close to the manufacturers stated size. The MTZ's I had previously were 3/4" smaller than stated size...
