Black Diamond 2" Lift
Sometime in the near future, I plan on lifting my JK with a coil spacer kit. I've been looking at the 2" kit from Black Diamond. I've been reading-up on installation of the kit, and I have a few questions.
First of all, will I need to buy anything other than the actual kit? According to JC Whitney, " 2" Kit includes: 4 thicker coil spring isolators to replace the factory isolators on the front and rear springs. 4 new suspension travel-stops prevent over-compression. Easy to install 2" spacer lift kit allows use of original shocks for added value. "
Also, will I need to relocate the brake lines? Will I need to buy an adjustable track bar? Anything else?
so I got the kit today, won't be able to put it on for another 2 weeks (no time)
but Ill post pics/writeup fo'sho.
ps if someone can link a thread for a coil spacer write up that'd be great, otherwise I'll just use a case of budweiser and some reading glasses.
http://project-jk.com/jeep-jk-write-...ation-write-up
https://www.jk-forum.com/forums/jk-write-ups-39/rough-country-2-1-2-lift-w-rcx-2-2-shocks-install-29671/
