Odd brake issue... need help
Old Jan 23, 2010 | 08:26 PM
mmacJK's Avatar
Question Odd brake issue... need help
Ok
So after I installed my lift and 35"s I noticed that when i go around a corner with the clutch engaged that if i break I feel a shuttering in the brake peddle and hear a noise.
It almost seems like the ABS is mis-engaging...
Ideas? I am totally clueless on this one.
Old Jan 23, 2010 | 08:40 PM
nangulator's Avatar
Originally Posted by mmacJK
Ok
Is your steering wheel straight?
Old Jan 23, 2010 | 08:43 PM
mmacJK's Avatar
Hey
Yah I got an alignment right after we did the lift and tires. Wheels are straight as is the steering wheel
Old Jan 23, 2010 | 08:47 PM
nangulator's Avatar
Do you get the esp or traction control light on when this happens? or abs light
Old Jan 23, 2010 | 08:50 PM
mmacJK's Avatar
Hmm
I have seen the ESP light flash. But I have also had it happen without the ESP coming on..
Old Jan 23, 2010 | 09:04 PM
nangulator's Avatar
i had the same problem. I did my alignment (I am an ase certified master tech) and use my aev pro-cal to center the steering wheel, but when I went down this one road and hit a bump while going through a turn, I had the same issue. I did my steering calibration again and have not had any problems since.
Old Jan 23, 2010 | 09:16 PM
mmacJK's Avatar
Hmm
So do you think I should take it back to the alignment shop I had it done at?
Old Jan 23, 2010 | 09:44 PM
nangulator's Avatar
Hmm
Well my question is, did you re-center your steering wheel electronically
Old Jan 23, 2010 | 10:03 PM
mmacJK's Avatar
I did not, but the alignment shop did. I recentered by look after the lift then went and had them do it by electronics.
Old Jan 24, 2010 | 07:45 AM
mmacJK's Avatar
any other ideas?
