Tracbar correct position....
Old Mar 13, 2010 | 06:29 AM
tento0929's Avatar
Default Tracbar correct position....
Hi, i just installed my 3'' full traction premium lift used on another jeep and im having some problems, since this tracbar is adjustable i just dont know wich is the right position and the trouble is that is makang allot of strange sounds in the chasis mount, im just guessing this has to do with the adjust. can any one help me please
thanks
Old Mar 13, 2010 | 06:36 AM
Mark Doiron's Avatar
I suggest that you review the write-ups linked on this page:
Jeep JK Write-Ups
Old Mar 13, 2010 | 11:37 AM
tento0929's Avatar
thanks
but since i have the lift kit installed allready i dont know how to measure the tracbar, if anyone can help with the lenght that it should go so it would work how is suposed to work.
its for a 2 door 2008 model
and i have the relocation braket because i also usea a fox steering stabilizer....
Old Mar 13, 2010 | 12:27 PM
spinlock's Avatar
I think he wants the length the track bar should be adjusted to.
A good starting point is the original track bar length plus a small increment less than the amount of lateral shift created by the 3" lift.
That lift is fairly popular, you can run a search for that kit and find and owner that has it. PM him for the length of his TB.
Persistent noises from the suspension after a lift is not a good thing.
Are you sure you installed the lift correctly AND torque everything to spec particularly the track bar?
Old Mar 13, 2010 | 04:45 PM
JungleJeep's Avatar
Get rid of the reloc bracker if you can. I AM SPEAKING FROM EXPERIENCE.
Old Mar 14, 2010 | 03:12 AM
Originally Posted by tento0929
thanks
but since i have the lift kit installed allready i dont know how to measure the tracbar ...
Sorry, I thought the instructions for installing the FT 3" Ultimate Lift would prove useful in making certain that you did it right (IOW, figuring out why you have a noise), and in helping you to get the track bar installed (there is a measurement in the instructions--guess it wasn't what you needed).
Old Mar 14, 2010 | 10:28 AM
tento0929's Avatar
yeah thanks im going to try this today and hope that solves the problem...
Originally Posted by 2k2wranglerx
so the trackbar is already installed and you need help on what length?
grab a tape measure, the upper spring perch has a hole in the top of it. that's a perfect reference point. hook the tape to that and measure to the outside of the widest lug on the tire. repeat on the other side.
So if it's 1" further out on the Passenger side you would shorten the track bar (screw the heim in). If it's further out on the drivers side, you would lengthen and unscrew the heim. You might have to do it once or twice to get it right.
A trick to lining up the holes to put the bolt in the lower track bar bracket, have a buddy sit in the jeep and move the steering wheel left or right. with the track bar disconnected that will move the body of the jeep to either side to make it easier to line up the bolt holes.
once you're done you'll probably need to straighten your wheel as well.
is that what you're asking?
Old Mar 16, 2010 | 05:19 AM
tento0929's Avatar
So, i did this and just spin it one to the inside and voila i thnk ive solved the problem, going to use it some days to see what happens.... thanks
