EVO Gusset install question
Old Mar 18, 2010 | 03:44 PM
Cat Dr.'s Avatar
Default EVO Gusset install question
For those of you that have installed the EVO Gussets, did you remove the ball joints or weld a small amount, cool the weld. Then move to the next gusset and repeat until finished? Part two to the same topic. Did you stick weld or wire feed? Thanks in advance.
Old Mar 18, 2010 | 04:00 PM
Castalone's Avatar
Wire feed. We did it with 2 of us. He weld about an inch at a time, I went after him and pour water on the area to keep it cool. No problems on 2 jeeps, our firs time.
Old Mar 18, 2010 | 04:12 PM
backwoodjk's Avatar
I spent about 1 hour welding each side. 1 1/2" welds, followed by wet rags. I have had no problems yet in the 3k miles that they have been on. I used a Lincoln wire feed.
Old Mar 18, 2010 | 04:36 PM
Cat Dr.'s Avatar
Thanks, I'll attempt it soon. I really didn't want to pull the ball joints.
Old Mar 18, 2010 | 04:59 PM
john smack's Avatar
We didnt even use any water just took our time from one to the next
Old Mar 18, 2010 | 05:54 PM
NTXJK's Avatar
Same here but I ran out of wire and gas I will finish them sat
Old Mar 18, 2010 | 06:14 PM
OnBelay's Avatar
I was at Off Road EVO this afternoon, and they quoted me about $230 (parts and labor). I imagine the labor would be $140ish ... if you decide to go that route instead.
