Zone 4in lift- Reviews Please
I haven't gotten it yet, but I have been hunting around and trying to something bad about these lifts. I can't find anything. It sounds like they are awesome lifts. Great bang for the buck! Let me know when you get it. I'm waiting for my tires to wear out, or to catch my wife in a weak moment!
cons - it's cheap
4" is a lot of lift and if you get this kit, i would recommend that you get a few more bare minimum parts to fill in the gaps. specifically, i would HIGHLY recommend that you at least get adjustable front lower control arm mounts so that you can add a bit more caster. DO NOT use the cam bolts if you plan on wheeling your jeep as they will require you to cut your control arm mounts into slots and this can cause you headaches down the road as the bolts ultimately come loose. I would also recommend that you get a front track bar relocation bracket and dropped pitman arm or draglink flip kit. at 4" of lift, your steering geometry will be very off without them and this will give you poor handling. of course, if you have a 2-door, you WILL need a new rear drive shaft sooner than later and in order to install a u-joint style shaft, you WILL need adjustable rear upper control arms so that you can set your pinion angle. another thing i would recommend is a set of extended brake lines and unless you're cool with the sloppy ride old school hydro shocks provide, i might recommend that you ditch what you get with this kit in favor of a set of OME or bilsteins. but, that's just my 2¢
pros - it's cheap
cons - it's cheap
cons - it's cheap
btw- wayalife your jeep is soo sick!
what about a 3in lift? im pretty new to the jeep world and know you guys can really help. the lift will be going on a 4dr jk (non rubicon) and i wont be doing a ton of flexing. i live in florida and it doesnt get to rocky here. im just looking for a good lift that will work good and drive good. thanks!
