Tire pressure
Old Mar 20, 2010 | 02:47 AM
ripmover's Avatar
Default Tire pressure
I have 4 door with 35" BFG KM2 on AEV Beadlocks. What is the best tire pressure for hwy/street driving. The shop that installed recommended 40psi. Is that to high?
Old Mar 20, 2010 | 04:42 AM
JPop's Avatar
Yep, Chalk test is the best way to fly.
Old Mar 20, 2010 | 11:28 AM
jeepmedic's Avatar
I run 28 as well.
Old Mar 20, 2010 | 11:36 AM
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
35 Toyo MT's here and 28 is my best ride number
Old Mar 22, 2010 | 03:14 AM
ripmover's Avatar
Thanks for the info. I guess i need to air down.
Old Mar 22, 2010 | 06:24 AM
Hog Man's Avatar
Yep, 30psi in mine. They had 40psi in them at one time and the ride was much more harsh and I wasn't getting a full contact patch either.
Old Mar 22, 2010 | 07:15 AM
Calypso's Avatar
Yep, chalk test and I bet you end up around 30psi or less. It's gonna ride SO much better!!!
Old Mar 22, 2010 | 07:22 AM
redrockin7's Avatar
I have the same 35x12.5x17 BFG KM2s on mine. Shop told me they set them at 32-34, but after driving a week (500 miles) and seeing the outside edge nipples still on there (i.e. edges not riding on ground b/c overinflated), I checked the pressure and it was at 38-40 range.
I dropped them down to 32psi and it improved the right quality (wasn't actually that bad at 40psi IMO even) and appears I am getting a more correct footprint. May drop down to 30psi even...
Old Sep 28, 2010 | 09:06 AM
G16's Avatar
G16
Default Chalk test
Could some one explain how to do a chalk test properly. I've never heard of this before.
Old Sep 28, 2010 | 10:17 AM
Merlin4979's Avatar
Check the link that the Planman listed. It has an exact "how-to" on doing a chalk test.
