RCV Axle Question. How to get shaft out of joint?
Old Mar 21, 2010 | 04:14 AM
gcally's Avatar
Default RCV Axle Question. How to get shaft out of joint?
I have a quick question about my RCV shafts.
How do you get the shaft out of the joint? I need to swap out a shaft and I cannot pull it out of the joint. I know there is a snap ring on the end of the shaft (joint end) but it will not budge. Do I need to use a press?
Old Mar 21, 2010 | 06:49 AM
seer1's Avatar
No help to you with that, but did you already break something?
Old Mar 22, 2010 | 03:55 AM
gcally's Avatar
No breakage I just need to swap out a shaft.
