all the different 3" TF lifts make my head hurt
Im still a noob. I was really leaning to their 2.5" lift but after seeing a ton of jeeps with the TF 3" lift that's what I want to get. There are 7 different 3" lifts all ranging from 800 dollars to just under 3000 dollars. What are the main differences in between them? And what would would be best for me. Where I am stationed at its mainly sand and hard packed dirt, little to no rocks, but who know where I will be stationed next.
So far the mods are a warn wench, LoD front bumper, MBRP rock rails and I will be ordering a rear bumper soon. Tires will come after I get the lift, I'm going to run stock wheels so I will also be ordering some spaces.
I know I will have to get new drive shafts, track bars and most likely a steering stabilizer, anything else I'm missing?
Thanks for the help.
Chris
Chris
are those needed or just nice to have? I have 21K on the jeep right now if that helps
You shouldn't need to replace the rear drive shaft, but definitely the front...unless you don't think you'll be disconnecting the front sway bar and/or flexing that much...also depend on whether you've got and auto or manual.
