Airaid Intake
Old Mar 24, 2010 | 09:50 AM
taher2.1's Avatar
Default Airaid Intake
Airaid intake was my first MOD and I love the sound but it keep getting dirty.
What is the best way to keep it clean and did I make a mistake getting this
Old Mar 24, 2010 | 10:08 AM
YingYang's Avatar
I have one also. It is gonna get dirty quickly if you wheel in a dusty enviroment.
Airaid sells as well as others (K&N etc.) a cleaning kit. It comes with a cleaning solution that breaks down the oil in the filter. Hose it off, let it dry and then use oil to recharge the filter (comes with the kit, redish color). Its not very time consuming, longest wait will be on the filter to dry. Run a ligh coating of oil on each fin and your good to go.
Old Mar 24, 2010 | 10:15 AM
RevyJKU08's Avatar
MKJeep has modified his Airbox with foam and sealed it more to help reduce a possible hydrolock. I am sure he will chime in and have photos!
Also, invest in a pre-filter it is basically a water repellent bag that fits over the airraid filter and pro-longs the cleaning intervals and helps filter out finer dust particles.
Old Mar 24, 2010 | 10:19 AM
mkjeep's Avatar
........Click image for larger version
no probs with mine.
Old Mar 24, 2010 | 10:40 AM
taher2.1's Avatar
Originally Posted by mkjeep
........Attachment 39318
no probs with mine.
That is nice. I will first clean it and do the same.
Where do i get the plastic cover from? this modification will not effect the performance of the jeep?
By the way...the engine is clean...I have mud and dirt all over
Old Mar 24, 2010 | 10:52 AM
mkjeep's Avatar
I used roof flashing and cut to fit. It's clean because every so often , I simple green it, then wd-40 everything.
Old Mar 24, 2010 | 10:57 AM
YingYang's Avatar
The pre-filter is roof flashing? Im lost
Thats a great idea with the foam and pre-filter, should help out.
Old Mar 24, 2010 | 11:10 AM
mkjeep's Avatar
Nooo, the roof flashing is the front of the airaid box since it didnt have one. Ordered the pre-filter from O'Reilly's auto parts.
Old Mar 24, 2010 | 12:23 PM
YingYang's Avatar
I missed that.
Whats the switch in your airbox?
Old Mar 24, 2010 | 01:17 PM
mkjeep's Avatar
My discombobilator. Everyone should have one.
