New Clunk Sound at low speed/turn
Old Mar 25, 2010 | 08:44 AM
PCHSahara's Avatar
Exclamation New Clunk Sound at low speed/turn
My TF BB install has been trouble free for over a month. This morning I appear to have gotten my first issue.
Backing up and turning, and then starting out slowing and turning (left or right) I am hearing 1 or 3 "clunks" as the vehicle starts / weight transfer occurs.
This is only happening at slow speed. Once you are moving along..there is no noise and no issues turning, etc...
Again..no issues with vibration, jumpy steering, etc. Its only when going from a stop and turning / to straighten out...
I can tell the noise is from the front.. and I think its from the driver side.
I checked the lug nuts and they are fine. I tugged on all the suspension components and none felt loose.
My suspension setup is: TF Perf BB with shocks, JKS discos, TF adj trackbar.
Can anyone identify the problem based on the issue described? A friend also suggested maybe the front drive shaft? I'm 6sp manual, 2.5lift, and was only in 2w drive at the time...
Tonight I will get out the tools and see if anything will tighten down further...
Old Mar 25, 2010 | 08:54 AM
Locklain's Avatar
I had a loose sway link that would clunk going backward to forward and every time the vehicle would lean. It was driving me nuts so I had a friend jump up and down on the bumper until I found the noise.
Old Mar 25, 2010 | 09:58 AM
PCHSahara's Avatar
thx for the replies. I'll torque everything down and see if that finds the culprit.
Old Mar 25, 2010 | 07:11 PM
PCHSahara's Avatar
All the bolts are tight. The only thing I've noticed is the tie rod bar (? where the steering stabilizer attaches) is pretty easily to twist. The end is connected to the driver wheel via a joint... So maybe its always supposed to move that easily (same with the bar above it) When it twist it by hand to the extreme, I hear it clank.
I'm not sure if thats the actual noise I hear when driving/turning, but it does seem like the design is supposed to twist...
grasping at straws here :-\
Old Mar 25, 2010 | 07:20 PM
PCHSahara's Avatar
yea i double checked the shocks..really shook them..no problems.. made sure the bottom bolts and the top screws were secure.
Old Mar 25, 2010 | 07:39 PM
babiehughie's Avatar
Check your battery. Mine was loose and "clanked" side to side when leaving the drive way, and on sharp, slow-speed turns. Drove me nuts until I found it. Fixed it with a piece of 1/8" tube squished between battery and battery hold-down.
Old Mar 25, 2010 | 07:47 PM
PCHSahara's Avatar
checked the battery..its secure..good suggestion tho!
I might try taking the whole shock off too. cant hurt to test!
Old Mar 26, 2010 | 12:26 PM
PCHSahara's Avatar
problem SOLVED!
It was the driver top swaybar JKS disconnect pin. The bolt had gotten a bit loose and allowed for the pin to jiggle. I thought I had used plenty of loctite! Anyway.. tightened it up and its good.
Only troubling thing to be is that the pin was able to jiggle up and down with the bolt not being firm.. .to me that sounds like the pin is not the same diameter as the sway bar hole... and will over time elongate the hole and this will happen even with the bolt tight!
Old Mar 26, 2010 | 04:03 PM
Locklain's Avatar
Originally Posted by PCHSahara
problem SOLVED!
I thought I had enough loctite on mine too but that is exactly what they did. This time around I tied two wrenches together (end to end) to get extra leverage and torqued the suckers down with enough force to squat the front end. They aren't going anywhere anymore.
