Note: for lifts on new 2010 JK's
Note: 2010 JK's have changed from 2007-2009's. Body mounts, frame is a little different for the better. The way the rear axle is mounted so you can shift it back a little to clear the front of the wheel well for 37's. You do not need to trim the pinch or joint seam or the stock RUBICON rock slider. The front of the rear wheel well is shaped different for the better so you do not hit it with 37's. They had to cut the cat and rotate 180 degrees and custom bend some exhaust. Make sure when buying a lift they have made the adjustments for a 2010.
Mark
Mark
