1 3/4 lift kit
I am wanting to lift my JK and keep my stock shocks 4 a while and not change any other major things 4 now. I have found a daystar kit on quadratec part #16058.100X and also a pro comp lift on ebay item #110470531370. Has anyone had any experience with either kit? Both look the same but would like some advice.
I am in process of maybe picking one up off a member here 4 $60 shipped. But my jeep is almost level already it is maybe 1/4 inch lower in front barely noticeable. I do not want it higher in the front since i will be pulling a boat with my JK. Right now with boat it sits slightly lower in rear I would like to keep it that way. I believe the same lift all around would work out better than TF leveling kit.
why the extended swaybar links with that small a spacer? I have those spacers and they compress to approx 1.5" under normal weight. if i disconnect the swaybar i get full flex anyway and I haven't had any issues yet. Do I need extended links?
