Help!! Need OEM bolts Help!!!
Old Mar 30, 2010 | 09:57 PM
Rub61's Avatar
Default Help!! Need OEM bolts Help!!!
I need OEM replacement driveshaft Flange Bolts. The small ones that take an 8mm socket. My OEM driveshaft is comming out to be replaced with Coast shaft. The OEM bolt heads are messed up from the dealer replacing the shaft after boot tear off. Looks like they used the wrong size socket on them. I need new bolts to replace the stock shaft if and when I need warranty work done. I can get the old bolts out but it ain't gona be pretty so I really need some new ones.
Thanks a Million for any advice
Old Mar 30, 2010 | 10:37 PM
KenB1010's Avatar
I just had a similar issue. Contact a local driveline shop to see if they have them. If not then a visit to the dealer is in order. My local dealer had them in stock
Old Mar 31, 2010 | 03:09 AM
jd1066's Avatar
I had to order a set from my dealer - they didn't have them in stock, but it only took a day to get them in. They sell them in pairs, so make sure you order 4 sets.
JD
Old Mar 31, 2010 | 09:17 AM
Rub61's Avatar
Thanks for all the advice.
Problem solved. The part # for these bolts is 68003249AB for a set of 2 + the plate. Will be delivered tomorrow.
Anybody have an idea what the torque on these bolts should be????
Thanks again
