brake line
Old Apr 1, 2010 | 11:22 AM
Default brake line
Guys,
I've installed my RC BB wt shocks and look at my brake line in the rear when it's on the lift... Do I need a relocation bracket ? Is it stretching to much ???
TKS !!!
Old Apr 1, 2010 | 11:25 AM
Calypso's Avatar
Oh yea!!!!!!!!!! That puppy is about to pop!
Old Apr 2, 2010 | 07:56 AM
warlord's Avatar
is that axel fully extended?
you might be able to get away with just fleximg the metal part of the line down a little.
but yes the safer and more reliable solution would be an extention
Old Apr 2, 2010 | 08:01 AM
pettym's Avatar
I don't see much that catches me off guard at first sight, but that did. I would change that ASAP.
Old Apr 2, 2010 | 08:04 AM
frankie945's Avatar
For the time being just unhook the brake line from the frame and keep it on the road till you get new lines or a relocation bracket. Like the one teraflex carries..
Old Apr 2, 2010 | 09:44 AM
nthinuf's Avatar
You can make them for cheap...
https://www.jk-forum.com/forums/modified-jk-tech-2/can-i-see-your-home-made-brake-line-extensions-91799/
Old Apr 4, 2010 | 05:53 PM
yeah, it's up on the lift....
Old Apr 4, 2010 | 05:54 PM
GoodysGotaCuda's Avatar
Absolutely those lines need to go, or be moved
Old Apr 5, 2010 | 02:35 AM
Mark Doiron's Avatar
Originally Posted by nthinuf
Yep, a buck or two at a hardware store and ten minutes of your time--before you go wheeling again!
Old Apr 13, 2010 | 12:15 PM
pettym's Avatar
I am installing the 2.5" TF coils on my JK this weekend and I thought about getting new brake lines but it seems this process works. Just by dropping the bracket a few inches, I am going to get the needed extention so I don't snap a brake line? Is this just a cheaper alternative to upgrading brake lines?
